Hi everyone,
I have been trying to use PAT to calibrate a building model using NSGA2 as optimization algorithm. Since this analysis might take quite a lot of simulations (10.000+), parallelization is important to reduce total experiment time.
The problem i am having is that when i set the "Max Queued Jobs" algorithm setting higher than 60 some of the simulation datapoints appear as "NA" and also some as "datapoint failure" (This does not happen when that setting is bellow 60).
Since the "Number of Samples" (size of initial population) i am using is around 136, the "Max Queued Jobs" setting is limiting the max simulations i can run at the same time.
Here is an example of what happens:
I am using OpenStudio-Server on AWS, with a node type "t3.xlarge".
I will post some screenshots of console errors when i have the chance.
Thanks!
