Hello,
I have recently started to use the Openstudio Application. In the older version (Open Studio 2.9.0) I used the "project loose geometry" feature in sketchup to create the windows, after intersect and matching the surfaces and it worked fine.
Since I installed the recent version of OpenStudio Application (v1.4.0) when I use "project loose geometry" feature, it creates diagonal lines in my interior walls, resulting with unmatching surfaces and this is really difficult to solve. I need to delete several times the new lines before redoing the matching surface. Is there a special workflow or condition for that feature to work correctly in the new application ? I don't know where to post this problem in the github page.
Thank you
