asked 2 years ago
willyJohan's avatar
Modelling heat loss from an outdoor heated pool using tools/inputs intended for basements
I'm hoping to model the impact different levels of insulation would have on heat loss from an in-ground pool.
I'm thinking this is basically just a basement with water instead of air and plan to model it as such.
I'm wondering if there is a way to account for the difference between air and water when modelling convective heat transfer as i assume this will be the major issue with this model.
Also curious to hear folks' general thoughts on how best to model heat transfer from an in-ground pool.
Thanks in advance.
Thanks in advance.
