Hello, I have an EnergyPlus file and would like to know where exactly I can change the setpoint temperature to 68 and 72 degrees Fahrenheit and how I should change the system from a boiler to a Heat Pump (using the R410 coolant).
| 1 | initial version |
| 2 | retagged |
