Is there a way to model Mitsubishi split-type air conditioners from performance curves? Link to the technical data of the system along with the curves is HERE. Is there any tutorial available or some guidelines? Also, which system (object) in EP is the best representation of the attached system? The model that I am using is MUZ-SF35VE.
