Hi....
I have ınstalled the radıance ın openstudıo.
I am gettıng this error message and ı cant able to solve thıs error.
[utilities.idf.Workspace] <1> URL Found in IDF: file:files/TUR_Izmir.172180_IWEC.epw but no source could be located. [openstudio.energyplus.ForwardTranslator] <0> Space Space 101 is not associated with a ThermalZone, it will not be translated. [openstudio.runmanager.ToolBasedJob] <1> ToolBasedJob error starting job: No tool matching: expandobjects 8.2.-.- no sql file given, running EnergyPlus... Creating rundir: C:/Users/Mumin/AppData/Local/Temp/OpenStudio.ne9756/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/ Creating workflow Running jobs The job in 'C:/Users/Mumin/AppData/Local/Temp/OpenStudio.ne9756/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/1-ModelToIdf-0' has warnings. WARN: Space Space 101 is not associated with a ThermalZone, it will not be translated. The job in 'C:/Users/Mumin/AppData/Local/Temp/OpenStudio.ne9756/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/2-ExpandObjects-0' did not finish successfully. ERROR: No tool matching: expandobjects 8.2.-.- Radiance export aborted. Adding path for local perl: C:/Program Files/OpenStudio 1.7.0/strawberry-perl-5.16.2.1-32bit-portable-reduced/perl/bin Setting RAYPATH: C:/Program Files/Radiance/lib, C:/Program Files/Radiance/bin, '.' Appending PATH: C:/Program Files/Radiance/bin, '.' 2015-06-07 10:51:49 UTC: running 'ruby -I 'C:\Users\Mumin\AppData\Local\Temp\OpenStudio.ne9756\resources\run\1-Ruby-0' -I 'C:\Program Files\OpenStudio 1.7.0\Ruby' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0\x64-msvcrt' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\site_ruby' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0\x64-msvcrt' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\vendor_ruby' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\2.0.0' -I 'C:\Program Files\OpenStudio 1.7.0\ruby-install\ruby\lib\ruby\2.0.0\x64-mingw32' -I 'C:\Program Files\OpenStudio 1.7.0\Ruby\' -I 'C:\Program Files\OpenStudio 1.7.0\Ruby\openstudio' -I 'C:\Program Files\OpenStudio 1.7.0\Ruby\lib' '.\ModelToRad.rb' 'C:\Users\Mumin\AppData\Local\Temp\OpenStudio.ne9756\resources\run\1-Ruby-0\in.osm' ''' 2015-06-07 10:51:56 UTC: completed. failed to run ModelToRad
Kındly help us..
