Hello,
We are trying to simulate a solar passive greenhouse complex for out end of program project in building eng.
We are using a gbxml file since it's a relative complex geometry.
Here's all my files.
It was able to run it well with result at the end but suddently it stop working and gave us this error message :
Initializing Simulation
Program terminated: EnergyPlus Terminated--Error(s) Detected.
[13:28:40.543600 DEBUG] Path for the OSW: C:/Users/RqphPC/AppData/Local/Temp/osmodel-1665508959-1\resources\workflow.osw
[13:28:40.611026 DEBUG] Initializing run method
[13:28:40.657254 DEBUG] Beginning run
[13:28:51.241909 WARN] Reporting Measure at C:/Users/RqphPC/AppData/Local/Temp/osmodel-1665508959-1/resources/measures/OpenStudioResults/measure.rb is using the old format where the 'arguments' method does not take model. Please consider updating this to def arguments(model).
[13:28:53.849740 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[13:28:53.850631 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'
:/openstudio_cli.rb:1173:in execute'
:/openstudio_cli.rb:803:inexecute'
:/openstudio_cli.rb:1972:in <main>'
eval:188:ineval'
eval:188:in require_embedded_absolute'
eval:173:inblock in require_embedded'
eval:167:in each'
eval:167:inrequire_embedded'
eval:126:in require'
eval:3:in<main>'
[13:28:53.854804 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1173:in execute'\n:/openstudio_cli.rb:803:inexecute'\n:/openstudio_cli.rb:1972:in <main>'\neval:188:ineval'\neval:188:in require_embedded_absolute'\neval:173:inblock in require_embedded'\neval:167:in each'\neval:167:inrequire_embedded'\neval:126:in require'\neval:3:in<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:241:in rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:238:incall_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1173:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1972:in<main>'\neval:188:in eval'\neval:188:inrequire_embedded_absolute'\neval:173:in block in require_embedded'\neval:167:ineach'\neval:167:in require_embedded'\neval:126:inrequire'\neval:3:in `<main>'"]}
Failed.
Simulation failed to run, with exit code 1
Thank you so much for your time and consideration !
