Hello,
I connected a boiler to the generator side of an absorption chiller (Chiller:Absorption:Indirect) by combining some of the example files that come along with Energy Plus 8.2. It's the first time I've done manual loop construction, and I've gotten the branch integrity to check out and set some extra sizing:plant loop objects so that I can autosize the chiller and boiler. But during warmup the inlet and outlet nodes of the demand side of the generator loop crash (-89.4C and -90.1C respectively). As the .err file suggests, I've manually increased operating capacity (boiler size = 6MW for a 130m2 building) and checked the operation schemes, although this is my first time working through these objects. I can't locate the source of the problem, although it does look there's 0W power getting from the supply to the demand side - the full 3MW of heating demand are unmet.
Any ideas about the next thing to look at (and maybe a good way to look at it?) would it be helpful if I included some of the code, or the .err file?
Thanks!
