I know that similar questions have been posted, but I will attach some picture to clarify. I have set 90.1-2013 - PriSchool - ASHRAE-169-2013-5B as the Construction Set for each Space except one which I have left as none in the FloorspaceJS editor as shown.
I have also set the default construction set for the building as 90.1-2013 - PriSchool - ASHRAE-169-2013-5B as shown:
When I go to the Spaces tab and view the Default Construction Set column, I see that the space I assigned to none in FloorspaceJS is empty as shown:
Shouldn't the space have inherited the default construction set from the building? Can someone explain what I did wrong?
