hey everyone, I am trying to use Energyplus from within Revit. There is an analysis option however I had to change the Open Studio to the latest version so that the analysis would work and generate results for HVAC and whole energy analysis.
I used this video to change the files over however, the charts or graphs usually associated with Energy plus do not export and I get some lines of code explaining that there is an issue with the output. https://www.youtube.com/watch?v=jUtnFJKwHzE
Has anyone else had these issues or if there is another way to get the results ie graphs and charts.
Thank you
