I am working with OpenStudio Application 1.4.0 in Sketchup 2022. I tried to run the simulation, however it always failed. The error information is as follows:
"Error executing argv: ["run", "-s", "56618", "-w", "C:/Users/������/AppData/Local/Temp/osmodel-1664356372-0\resources\workflow.osw"]
Error: incompatible character encodings: UTF-8 and GBK in eval:494:in `absolute_path'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/adapters/input/local.rb:46:in `initialize'
:/openstudio_cli.rb:1047:in `new'
:/openstudio_cli.rb:1047:in `execute'
:/openstudio_cli.rb:803:in `execute'
:/openstudio_cli.rb:1972:in `<main>'
eval:188:in `eval'
eval:188:in `require_embedded_absolute'
eval:173:in `block in require_embedded'
eval:167:in `each'
eval:167:in `require_embedded'
eval:126:in `require'
eval:3:in `<main>'
Simulation failed to run, with exit code 1"
Have you ever met the similar errors. Could you please tell me how to fix it?
