CondFD Surface Temperature Node not showing
I am simulating an EnergyPlus model with PhaseChangeHysteresis object.
Based on the RDD file it says that I can report "CondFD Surface Temperature Node" for nodes 1 to 29. However, for a specified exterior wall (which include PCM), the output table reports nodes 1 to 20 and not 29. other surfaces like a ceiling, (without PCM) it shows all temperature nodes from 1 to 29. I appreciate any help.
