To whom it may concern,
I exported a file from OpenStudio to EnergyPlus in order to run a simulation directly in EnergyPlus. I already ran some simulations in EnergyPlus and got a couple of warnings. Nevertheless, I finally got the output file. I would like to extract the hourly reports for different parameters by the end of the process. A couple of years ago, I remember that I selected some parameters on a checklist in eQuest and the hourly reports were displayed in the output file after the run. I was thinking about adding a couple of command lines in the input file in EnergyPlus and then run the simulation. Or which other paths can I take? Any comments will be highly appreciated!
Kind regards,
José Luis Bermúdez Alcocer, Ph.D.
