I'm using OpenStudio Version 1.4.0+ based on SDK version 3.4.0. When using the OpenStudio Results measure it seems that it writes stuff into eplusout.sql that DVIEW cannot read and makes it silently crash (i.e. without any error code or message - just gone). Does anyone else have seen the same behavior or can replicate on a simple file? And did anyone find a work-around to use both results option at the same time? I currently run the simulation twice, removing the OpenStudio Results measure when I want to check output variables with DVIEW - not really optimal if you have to simulate a large model.
