Can anyone help me decipher what the following eplusout.err error codes mean? It's a very basic 6 room model with a few windows, nothing fancy.
Program Version,EnergyPlus, Version 8.2.0-8397c2e30b, YMD=2015.05.27 15:45,IDD_Version 8.2.0 *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 2979 BuildingSurface:Detailed, *** indicated Name=Surface 371 *** Only last 3 lines before error line shown..... *** 2980 Surface 371, !- Name *** 2981 Roof, !- Surface Type *** 2982 , !- Construction Name
* Severe * IP: IDF line~2982 Error detected in Object=BUILDINGSURFACE:DETAILED, name=SURFACE 371 * ~~~ * Field [Construction Name] is required but was blank *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 2979 BuildingSurface:Detailed, *** indicated Name=Surface 371 *** Only last 4 lines before error line shown..... *** 2980 Surface 371, !- Name *** 2981 Roof, !- Surface Type *** 2982 , !- Construction Name *** 2983 , !- Zone Name
* Severe * IP: IDF line~2983 Error detected in Object=BUILDINGSURFACE:DETAILED, name=SURFACE 371 * ~~~ * Field [Zone Name] is required but was blank *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 3003 BuildingSurface:Detailed, *** indicated Name=Surface 694 *** Only last 3 lines before error line shown..... *** 3004 Surface 694, !- Name *** 3005 Roof, !- Surface Type *** 3006 , !- Construction Name
* Severe * IP: IDF line~3006 Error detected in Object=BUILDINGSURFACE:DETAILED, name=SURFACE 694 * ~~~ * Field [Construction Name] is required but was blank *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 3003 BuildingSurface:Detailed, *** indicated Name=Surface 694 *** Only last 4 lines before error line shown..... *** 3004 Surface 694, !- Name *** 3005 Roof, !- Surface Type *** 3006 , !- Construction Name *** 3007 , !- Zone Name
* Severe * IP: IDF line~3007 Error detected in Object=BUILDINGSURFACE:DETAILED, name=SURFACE 694 * ~~~ * Field [Zone Name] is required but was blank * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details.
* Severe * IP: Blank "required" fields found in input
* Severe * IP: Out of "range" values and/or blank required fields found in input
* Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=6 ..... Last severe error=IP: Out of "range" values and/or blank required fields found in input *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 6 Severe Errors; Elapsed Time=00hr 00min 1.00sec
