Hi, i'm developing a Reinforcement Learning(RL) framework using EnergyPlus as the simulation enviroment.
I'm having an hard time figuring out which object to access during runtime in order to modify the temperature setpoint of a zone. Right now i have
ZoneControl:Thermostat,
ZONE ONE Thermostat, !- Name
ZONE ONE, !- Zone or ZoneList Name
ALWAYS 4, !- Control Type Schedule Name
ThermostatSetpoint:DualSetpoint, !- Control 1 Object Type
Temperature Setpoints; !- Control 1 Name
Office Thermostat Dual SP Control, !- Name
ALWAYS 20, !- Heating Setpoint Temperature Schedule Name
ALWAYS 24; !- Cooling Setpoint Temperature Schedule Name
Always N are schedules that set value to N for all the 24h of a day.
I get that i have to use the get_actuator_handle() and then set_actuator_handle() but i can't figure out the names/instances of the variables i need to access/retrieve in order to do that.
Do i need to add actuators or new objects in the idf file?
Thanks in advance for the response
