Hi, I am working on a project with more than 70 variables, and I found that with the increase in the number of variables, the length of the name of the output folder for each job also increases. In extreme cases where I have more than 100 variables, the length of the name will exceed the maximum number of characters allowed by pc (around 260 characters), and this will lead to an error since it cannot generate this output folder.
I was wondering if there is a way to rename or change the default way to name the output folder for the optimization job run by jEPlus+EA.
