Hello, I have OS 1.4.0 installed on a macOS Monterey v.12.3.1, with a pathway to DView set up on the Results Summary tab. I downloaded DView from here - https://github.com/NREL/wex/releases/tag/v1.0.0
DView opens on its own, but will not open the OS .sql file, or launch from the Results Summary tab. It will ask if I would like the convert the units, then spinning ball, then crash. This has happened multiple times. Would it help to see the error log?
Thank you, Adelheid
