Start Simulation For ThermalZone With IdealLoadsAirSystem In C#
hello to all friend, I have created a simple example consisting of a thermal zone with door and window. Also, I have considered an ideal system for it, I have created the osm file, now I want to get the energy simulation as well as the calculation of the thermal and cooling loads of the system for this thermal zone, which class should I use to Start perform the simulation ?
I wrote the following code to analyze the model that I have attached the osm file But at the time of execution, it gets an error from modelmeasure For modelmeasure, it is not possible to create a manufacturer, thank you for your guidance
OpenStudio.WorkflowJSON workflowJSON = new OpenStudio.WorkflowJSON(); OpenStudio.Workspace workspace = new OpenStudio.Workspace(); OpenStudio.OSArgumentVector arguments = new OpenStudio.OSArgumentVector(); OpenStudio.OSArgumentMap argumentmap = new OpenStudio.OSArgumentMap(); OpenStudio.OSRunner oSRunner = new OpenStudio.OSRunner(workflowJSON); oSRunner.setLastOpenStudioModel(this.Model); oSRunner.validateUserArguments(arguments, argumentmap); oSRunner.setLastEnergyPlusWorkspace(workspace);
oSRunner.registerFinalCondition("Generated report"); oSRunner.registerInitialCondition("");
OpenStudio.ModelMeasure modelMeasure = null; modelMeasure.run(this.Model, oSRunner, argumentmap);
oSRunner.registerInitialCondition(""); OpenStudio.ModelMeasure modelMeasure = null; modelMeasure.run(this.Model, oSRunner, argumentmap);
argumentmap);
