I'm trying to model a DHW system in Openstudio, and the simulation report is showing an energy expenditure that only makes sense if the water heater is on-cycle 24 hours a day. I've double checked that hot water temp is below the heater maximum temp, and I don't know what else could be happening. Is there a way to manually define cycle fraction for a hot water heater, or is it all handled autonomously?
The only clue I have to this problem is this message in the eplusout file:
* Warning * CalcEquipmentFlowRates: "COMMUNAL WATER EQUIPMENT" - Target water temperature is greater than the hot water temperature (28.55 C)
* ~~~ * Environment=MIRAMICHI ANN CLG .4% CONDNS DB=>MWB, at Simulation time=07/21 00:00 - 00:10
* ~~~ * ...target water temperature = 43.33 C
* ~~~ * ...hot water temperature = 14.78 C
* ~~~ * ...Note: target water temperature should be less than or equal to the hot water temperature
* ~~~ * ...Target water temperature should be less than or equal to the hot water temperature. Verify temperature setpoints and schedules.
