Do I need to define constraints for running Sensitivity Analysis using Morris Method in jEplus+EA?
I am running a sensitivity analysis using the Morris method in jEPlus+EA, and I have defined my parameters, outputs and objectives but no constraints are defined. My question is, do I must define constraint? if yes, can you please describe it in simple words? Thanks
