radiant surface for both floor heating and cooling
Hi there, I am working on a building with air-to-water heat pump systems and underfloor heating and cooling using radiant surface.
I first defined a HP with hot water loop for floor heating (see attached diagram), and now I am wondering if I can use the same loop and HP for cooling as well, or I need to design another cooling water loop with a new HP system. Thanks in advance.
I first defined a HP with hot water loop for floor heating (see attached diagram), and now I am wondering if I can use the same loop and HP for cooling as well, well (which means an air to water reversible heat pump), or I need to design another cooling water loop with a new HP system. Thanks in advance.
I first defined a HP with hot water loop for floor heating (see attached diagram), and now I am wondering if I can use the same loop and HP for cooling as well (which means an air to water reversible heat pump), or I need to design another cooling water loop with a new HP system. Thanks in advance.
