Many IDF objects are still not supported by the OpenStudio SDK.
However we would like to run these IDF objects on OpenStudio Server.
I suspect that the best way to do so (and perhaps the only?) would be to inject these IDF objects via an EnergyPlus measure once the OpenStudio workflow is running on the OpenStudio Server.
I'd appreciate any input on this question. Does this sound correct?
Thank you!
