Setpoint Locating setpoint manager for HX assisted coil
Hi there,
I am using CoilSystem:Cooling:Water:HeatExchangerAssisted in order to simulate a desiccant-wrapped cooling coil.
I wonder how I can set up my air temperature setpoint manager in the HX Exhaust Air Outlet Node.
The ChW of the cooling coil in between the desiccant will be a controller.controller. The cooling coil will control both temperature and humidity ratio.
There will be a preheating coil before the 'HX Supply Air Inlet Node'.
For my case, With the preheating coil and a HX wrapped cooling coil in between sometimes operates unintentionally to result in deviation from coil, how could I control the setpoint temperature.
temperature at the 'HX Exhaust Air Outlet Node'.
Please let me know if you have a similar experience.
Thank you in advance.
