I used surface inside air temperature and surface outside air temperature output variables of OS for hourly temperature changes in MN (24hr). Looking at July and Jan, the inside temp is almost constant even with severe temp changes in the outside surface. I am using heating and cooling thermostat Schedule. How can I change the variables to get different inside surface temp with changing outside temp?C:\fakepath\Outside & inside temp Changes-24hr.JPG
