Hi all,
For air distribution using AirLoopHVAC, I need to set the supply and return air to the same zone. I would like to simulate airflow with supply air in zones 1 and 2 and return from zones 3 and 4.
I have tried to create the same situation as above by setting the cross-sectional area of the ducts in the return paths of zones 1 and 2 and the supply paths of zones 3 and 4 to almost zero. Please let me know if there is another appropriate method.
Thanks.
