I am trying to run some of the PAT 3.4 sample projects on a Kubernete cluster on AWS. I have deployed the cluster and installed the Helm chart according to the instructions here. Everything seems to be working when I run kubectl get pods
NAME READY STATUS RESTARTS AGE
db-65f4c9ccf6-2928g 1/1 Running 0 3m
openstudio-server-nfs-server-provisioner-7784b767d-777qs 1/1 Running 0 3m
redis-5ffc4f5d9f-vk4pv 1/1 Running 0 3m
rserve-6f7545dfb7-p59tw 1/1 Running 0 3m
web-5fcf97d7b5-xqzvm 1/1 Running 0 3m
web-background-75689b764f-wm5n7 1/1 Running 0 3m
worker-659779bcdb-7zfqf 1/1 Running 0 3m
worker-659779bcdb-tnzvp 1/1 Running 0 2m45s
I can connect to the server in the PAT application, but when I run the analysis each datapoint fails with the error datapoint failure. This is an extract of a datapoint log
07:32:01.115794 INFO] Creating Workflow Manager instance
[07:32:01.115835 INFO] Directory is /mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/data_point_295390e1-1aed-4689-981e-694042a782c7
[07:32:01.115898 INFO] Opening run.log file '/mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/data_point_295390e1-1aed-4689-981e-694042a782c7/run/run.log'
[07:32:01.117454 INFO] Running workflow using cmd /usr/local/bin/openstudio run --workflow '/mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/data_point_295390e1-1aed-4689-981e-694042a782c7/data_point.osw' and writing log to /mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/data_point_295390e1-1aed-4689-981e-694042a782c7/oscli_simulation.log
[07:32:10.068773 ERROR] Workflow /mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/data_point_295390e1-1aed-4689-981e-694042a782c7/data_point.osw failed with error Oscli returned error code 1
[07:32:10.068841 WARN] UrbanOpt simulation output: does not exist
[07:32:10.068858 WARN] UrbanOpt process output: does not exist
[07:32:10.068933 INFO] Oscli output: [07:32:09.978669 ERROR] undefined method `create_prototype_building' for #<OpenStudio::Model::Model:0x00005648c0e8f670>
/mnt/openstudio/analysis_a8dd7547-6018-46ee-b137-e7f6133116f5/measures/2c6d68ea-2acb-4774-85ab-d77de08d77bd/measure.rb:148:in `run'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:517:in `apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'
:/openstudio_cli.rb:1173:in `execute'
:/openstudio_cli.rb:803:in `execute'
:/openstudio_cli.rb:1972:in `<main>'
eval:188:in `eval'
eval:188:in `require_embedded_absolute'
eval:173:in `block in require_embedded'
eval:167:in `each'
eval:167:in `require_embedded'
eval:126:in `require'
eval:3:in `<main>'
I am not a docker expert, let alone a kubernete one, but when I login in the actual EC2 instances for the worker nodes I would expect to find this file /usr/local/bin/openstudio, but it does not exist.
Any suggestion?
