I'm running ground source heat pump with energyplus.
Simulation works well, but can't find method to see ground temperature around the ground heat exchanger with coordinate system.
I can't see directly such as ground temperature recovery or other things.
i found output variable 'Ground Heat Exchanger Average Borehole Temperature', but it's quite different i looking for.
is there any see ground temperature?
in depth or coordinate system.
