The building has DOAS + VRF and I want to know the space cooling loads. Is there a way to model DOAS in the ideal loads system to get the cooling load ? Any help will be greatly appreciated !
Thank you
![]() | 1 | initial version |
Thank you
![]() | 2 | No.2 Revision |
The building has DOAS + VRF and I want to know the space cooling loads. Is there a way to model Openstudio DOAS in the ideal loads system to get the cooling load ? Any help will be greatly appreciated !
Thank you
