Hi all. I am simulating a room with a window for calculating an illuminance map with daylighing Control on OpenStudio. I added a Radiance Measure in OS and ran the model. The Problem is that as i add the Radiance Measure, the OpenSturio deletes the daylighting controls and the results is as when I have no daylighing control!!! I do not know where is the problem with that. I appreciate whoever can help!
