Hi. Im using Energyplus. I wanna setting humidistat in energyplus. However, im using Fan Coils HVAC system. at the first im using HVACTemplates:FanCoil. I need to keep the RH between 60-70 % and Temperatures 23-25 C.
Please anyone help me thanks.
Here my HVACTemplates:FanCoil Code
HVACTemplate:Zone:FanCoil,
Gudang RM, !- Zone Name
RM 03 Target 23-25, !- Template Thermostat Name
3, !- Supply Air Maximum Flow Rate {m3/s}
, !- Zone Heating Sizing Factor
, !- Zone Cooling Sizing Factor
Flow/Person, !- Outdoor Air Method
0.00944, !- Outdoor Air Flow Rate per Person {m3/s}
, !- Outdoor Air Flow Rate per Zone Floor Area {m3/s-m2}
, !- Outdoor Air Flow Rate per Zone {m3/s}
Infiltration 2, !- System Availability Schedule Name
0.8, !- Supply Fan Total Efficiency
1618.8, !- Supply Fan Delta Pressure {Pa}
0.8, !- Supply Fan Motor Efficiency
1, !- Supply Fan Motor in Air Stream Fraction
ChilledWater, !- Cooling Coil Type
Infiltration 2, !- Cooling Coil Availability Schedule Name
10, !- Cooling Coil Design Setpoint {C}
HotWater, !- Heating Coil Type
, !- Heating Coil Availability Schedule Name
50, !- Heating Coil Design Setpoint {C}
, !- Dedicated Outdoor Air System Name
TemperatureDifference, !- Zone Cooling Design Supply Air Temperature Input Method
20, !- Zone Cooling Design Supply Air Temperature Difference {deltaC}
SupplyAirTemperature, !- Zone Heating Design Supply Air Temperature Input Method
0, !- Zone Heating Design Supply Air Temperature Difference {deltaC}
, !- Design Specification Outdoor Air Object Name
, !- Design Specification Zone Air Distribution Object Name
, !- Capacity Control Method
0.33, !- Low Speed Supply Air Flow Ratio
0.66, !- Medium Speed Supply Air Flow Ratio
Infiltration 2, !- Outdoor Air Schedule Name
Electric, !- Baseboard Heating Type
Infiltration, !- Baseboard Heating Availability Schedule Name
0; !- Baseboard Heating Capacity {W}
Thanks for your Help!!
