I'm new using OpenStudio and the first time I tried to run a simulation it failed. There is in fact another issue just like mine in this forum but the solution didn't applied to my case.
Here is what appeared on the 'Run simulation' tab: Initializing workflow. Processing OpenStudio Measures. Translating the OpenStudio Model to EnergyPlus. Processing EnergyPlus Measures. Starting Simulation. EnergyPlus Starting EnergyPlus, Version 9.6.0-4b123cf80f, YMD=2022.06.06 17:33 **FATAL:Errors occurred on processing input file. Preceding condition(s) cause termination. EnergyPlus Run Time=00hr 00min 0.10sec Program terminated: EnergyPlus Terminated--Error(s) Detected. Failed.
The file stderr is empty. The file stdout has the following text:
[17:17:41.058130 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[17:17:41.058512 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'
:/openstudio_cli.rb:1067:in execute'
:/openstudio_cli.rb:803:inexecute'
:/openstudio_cli.rb:1855:in <main>'
eval:186:ineval'
eval:186:in require_embedded_absolute'
eval:171:inblock in require_embedded'
eval:165:in each'
eval:165:inrequire_embedded'
eval:124:in require'
eval:3:in<main>'
[17:17:41.060172 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1067:in execute'\n:/openstudio_cli.rb:803:inexecute'\n:/openstudio_cli.rb:1855:in <main>'\neval:186:ineval'\neval:186:in require_embedded_absolute'\neval:171:inblock in require_embedded'\neval:165:in each'\neval:165:inrequire_embedded'\neval:124:in require'\neval:3:in<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:241:in rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:238:incall_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1067:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1855:in<main>'\neval:186:in eval'\neval:186:inrequire_embedded_absolute'\neval:171:in block in require_embedded'\neval:165:ineach'\neval:165:in require_embedded'\neval:124:inrequire'\neval:3:in `<main>'"]}
Here it is a google drive link to the files: https://drive.google.com/drive/folders/14c8qCta48uOxcfCcy64JvsLfaArYDTVc?usp=sharing
