Hello,
I am getting the following error when running energy pro v8 non residential simulation. I attempted to correct the model based on the errors messages and re run the simulation, however the simulation fails to run.
Any pointer to resolve these issues will be helpful.
below is snippet of typical error message.
2022-05-26 11:46:22 - Error: Table look-up failed: VentilationSpaceFunctionData:VentOccDensSim( VentFuncType='' ) | ERROR: Table row match not found evaluating run u rule: Set DEFAULT Spc:VentOccDensSim (27:'Space-Ventilation.rule' line 978)
2022-05-26 11:46:22 - Error: Undefined data: left side of '' evaluating run u rule: Set DEFAULT Spc:CodeVentPerAreaForDCVFlow (27:'Space-Ventilation.rule' line 2013) 2022-05-26 11:46:22 - Error: Undefined data: left side of '' evaluating run u rule: Set DEFAULT
2022-05-26 11:46:22 - Error: Undefined data: second argument of max() evaluating run u rule: Set DEFAULT Spc:CodeVentFlow (27:'Space-Ventilation.rule' line 3046)
2022-05-26 11:46:22 - Error: Undefined data: left side of '' evaluating run u rule: Set DEFAULT Spc:CodeDsgnExhACH (28:'Space-Exhaust.rule' line 1799) 2022-05-26 11:46:22 - Error: Undefined data: left side of '' evaluating run u rule: Set DEFAULT Spc:CodeDsgnExhACH (28:'Space-Exhaust.rule' line 1799)
022-05-26 11:46:22 - Error gathering data to create PolyLp object: ExtWall 'srf36812' undefined 2022-05-26 11:46:22 - Error gathering data to create PolyLp object: ExtWall 'srf36812' undefined - Unable to generate building geometry for simulation (return code -3) 2022-05-26 11:46:22 - Analysis aborted Processing time: Overall 0:01 / SDD2IDF x0 0:00 / SizSim x0 0:00 / AnnSim x0 0:00 / ReportGen x0 0:00 / Other 0:01 2022-05-26 11:46:22 - ResultsSummary population: bAbort = (true) / RuleProcAbort = (false) / iRetVal = 9 / pszResultsSummary = (empty) / iResultsSummaryLen = 2056
Thanks, Aditya
