Can I measure the time lag and decrement factors of different wall constructions?
| 1 | initial version |
Can I measure the time lag and decrement factors of different wall constructions?constructions?
I am using EnergyPlus and OpenStudio.
Can I measure the time lag and decrement factors of different wall constructions? I am using EnergyPlus and OpenStudio.
| 6 | retagged |
| 7 | retagged |
Update: Thank you for your answer. I used the "Add output variable" measure to OS measures and ran the simulation, but opening the OS results report, There is no data available for Surface temp when I look into "openstudio Results" Report. Couldn't figure out what is the mistake in data input request. C:\fakepath\Surface outside air temp.JPGHere is the link to my OS simulation file.
https://drive.google.com/file/d/1WZFH...
