Hi
I am strugeling with E+ and output:variables. I need to do multiple simulations I use Eppy, but I have troubles for adding output:variables. I use the command idf.newidfobject...it works because it writes the output:variables to the IDF files, but CSV includes only the first output:variable data although IDF shows plenty of variables. I need to do multiple simulations and work with multiple results....
In addition I tried EP lunch for adding output:variables....it writes output:variables to IDF but the CSV is totally empty :(.
Adding meter data is dooable under output:variable?
Thanks
