Hello everyone, through the simulation I made I get the error below, does anyone have an idea how to solve it or i can send him or her the IDF file to take a look. I'll be so grateful for ur helps.
Program Version,EnergyPlus, Version 9.2.0-921312fa1d, YMD=2022.05.20 12:43, *** Beginning Zone Sizing Calculations * Warning * GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input. * ~~~ * Found first in surface=SURFACE 1 * ~~~ * Defaults, constant throughout the year of (18.0) will be used. * Warning * CalculateZoneVolume: 2 zones are not fully enclosed. For more details use: Output:Diagnostics,DisplayExtrawarnings; * Severe * GetZoneEquipmentData1: Number of Controlled Zone objects [6] greater than Number of Zones [3] * Fatal * GetZoneEquipmentData1: Too many ZoneHVAC:EquipmentConnections objects. ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=GetZoneEquipmentData1: Number of Controlled Zone objects [6] greater than Number of Zones [3] *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 2 Warning; 1 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 2 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.46sec
