I am using EMS to compute an intermediate value based on the available sensors. To check that the correct values are used in the EMS calculations, I created customized EMS outputs for those sensors and compared them with their values produced in the ESO file. For example, one of the sensors is the System Node Wetbulb Temperature of the Air Loop Demand Side Outlet as follows:
Actual sensor reading:
Output:Variable, Air Loop Demand Side Outlet, !- Key Value System Node Wetbulb Temperature, !- Variable Name timestep; !- Reporting FrequencyEMS sensor reading definition and it custom output:
Output:Variable, *, !- Key Value AirLoopWetbulb_Temperature_EMS, !- Variable Name timestep; !- Reporting Frequency EnergyManagementSystem:Sensor, AirLoopWetbulb_Temperature, !- Name Air Loop Demand Side Outlet, !- Output:Variable or Output:Meter Index Key Name System Node Wetbulb Temperature; !- Output:Variable or Output:Meter Name EnergyManagementSystem:OutputVariable, AirLoopWetbulb_Temperature_EMS, !- Name AirLoopWetbulb_Temperature, !- EMS Variable Name Summed, !- Type of Data in Variable !Averaged, !- Type of Data in Variable ZoneTimeStep ; !- Update Frequency
Is there a way to eliminate or minimize this error? I tried different EMS Program Calling options as follows:
For EMS Run , !- Name
BeginTimestepBeforePredictor, !- EnergyPlus Model Calling Point
!AfterPredictorBeforeHVACManagers
!EndOfZoneTimestepAfterZoneReporting
!EndOfZoneTimestepBeforeZoneReporting
EMSProgram1; !- Program Name 1
Thank you.
