Dear Everyone,
I want to compare two different systems in a building.
The first is geothermal heat pump and the second is VRF.
The outputs of the geothermy are correct but the data of the VRF are not
because the terminal heating coil load are zero for all months in the table air system
simulation results when i am running print/view simulation results
