Hello, I am a student studying Energy Plus. I want to implement a double skin facade system with SketchUp. So I created a new zone in the form of a curtain wall on the exterior wall of the building.
*** * Severe * Temperature (high) out of bounds for zone=DSFS1 for surface=DSFS1_FRAME5 *** * ~~~ * This error occurred 52681 total times; *** * ~~~ * during Warmup 0 times; *** * ~~~ * during Sizing 0 times. *** * ~~~ * Max=370.288517 C Min=200.00516 C
===== Final Error Summary ===== *** The following error categories occurred. Consider correcting or noting. *** Temperature (high) out of bounds *** ..A temperature out of bounds problem can be caused by several things. The user should check: *** ..1) the weather environment (including the horizontal IR from sky) *** ..2) the level of interal gains with respect to the zone *** ..3) the thermal properties of their materials. And other things. *** ..A common cause is a building with no or little thermal mass - all materials with Material:NoMass definitions. *** Nominally Unused Constructions *** ..The nominally unused constructions warning is provided to alert you to potential conditions that can cause *** ..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm *** ..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
How can I fix this error?
