I want to model a building with a basement floor. There is a sunken plaza, and part of the basement floor is exposed to outdoors.
I'm considering two options for how to set Z coordinate.
- Option A: Z=0 at 1F level.
- Option B: Z=0 at B1F level.
Which Option should be used? Or either is fine? I'm not sure what kind of problems arise in EnergyPlus.
I thought Option A (i.e., Outside Boundary Condition of a wall whose Z coordinate is less than 0 is Outdoors.) might not work, but when I tried, the simulation ran successfully. I got the following warning message, but it doesn't seem to be much of a problem.
** Warning ** CalcSurfaceCentroid: 1 Surface has the Z coordinate < 0.
** ~~~ ** ...in any calculations, Wind Speed will be 0.0 for these surfaces.
** ~~~ ** ...in any calculations, Outside temperatures will be the outside temperature + 9.750E-003 for these surfaces.
** ~~~ ** ...that is, these surfaces will have conditions as though at ground level.
