Hello Guys,
I have a problem that when I start a simulation in OS file with PTAC, I meet a problem as the image. But I don't know a solution for the problem. Actually, when I try to simulate another HVAC system as "Zone HVAC Low Temperature Radiant Variable Flow", I am facing the same problem again. I need your help these days, which is close to my exam. The image is below. C:\fakepath\image.JPG You can look the file via link (link text).
Thank you.
