I took some time off after how unstable OS App was and today I downloaded it for some work assigned to me. Not even 5 minutes into it, it has deleted my work and crashes, just like the old days. I thought this had been fixed. I have made a video here https://youtu.be/TW4PyVjiDt8. In the old days i got around this by using the external floorplan.json editor directly. Do i still need to do that? https://nrel.github.io/floorspace.js/ Is there any way for it to restore the work i've done? Why did it delete it? i tried to attach the floorplan.json but i guess it's a blocked file type, so i pasted it below..
Thanks
{"application":{"currentSelections":{"story":null,"story_id":"5","subselection_ids":{"5":"73"},"component_id":null,"component_definition_id":null,"component_instance_id":null,"space_property_id":null,"tool":"Rectangle","mode":"spaces","snapMode":"grid-strict","modeTab":"floorplan","subselectionType":"spaces"},"modes":["spaces","shading","building_units","thermal_zones","pitched_roofs","space_types","images"],"tools":["Pan","Drag","Rectangle","Polygon","Eraser","Select","Map","Fill","Place Component","Image","Apply Property"],"scale":{"x":{"pixels":1467,"rwuRange":[-12.5,262.5]},"y":{"pixels":796,"rwuRange":[-14.608043626448534,134.60804362644853]}}},"project":{"config":{"units":"ip","unitsEditable":true,"language":"EN-US"},"north_axis":0,"ground":{"floor_offset":0,"azimuth_angle":0,"tilt_slope":0},"grid":{"visible":true,"spacing":1},"view":{"min_x":82.22303784108631,"min_y":-907.8950230029586,"max_x":244.6095287876479,"max_y":-819.7834709965078},"map":{"initialized":false,"enabled":false,"visible":true,"latitude":39.7653,"longitude":-104.9863,"zoom":4.5,"rotation":0,"elevation":0},"previous_story":{"visible":true},"show_import_export":false,"preview3D":{"enabled":false}},"stories":[{"id":"5","handle":null,"name":"Story 1","image_visible":true,"below_floor_plenum_height":0,"floor_to_ceiling_height":8,"above_ceiling_plenum_height":0,"multiplier":1,"color":"#332288","geometry":{"id":"6","vertices":[{"id":"9","x":0,"y":0,"edge_ids":["16","84"]},{"id":"10","x":250,"y":0,"edge_ids":["22","25"]},{"id":"11","x":250,"y":120,"edge_ids":["15","32"]},{"id":"12","x":0,"y":120,"edge_ids":["15","16"]},{"id":"26","x":236,"y":0,"edge_ids":["30","22","49"]},{"id":"27","x":236,"y":20,"edge_ids":["30","31","47"]},{"id":"28","x":250,"y":20,"edge_ids":["31","32","25"]},{"id":"50","x":222,"y":0,"edge_ids":["53","49","60","63"]},{"id":"51","x":222,"y":20,"edge_ids":["53","47","70"]},{"id":"64","x":205,"y":0,"edge_ids":["60","77","80","90"]},{"id":"65","x":205,"y":27,"edge_ids":["69","87"]},{"id":"66","x":222,"y":27,"edge_ids":["69","70","63"]},{"id":"81","x":193,"y":0,"edge_ids":["84","85","77"]},{"id":"82","x":193,"y":20,"edge_ids":["85","86"]},{"id":"83","x":205,"y":20,"edge_ids":["86","87","80","91"]}],"edges":[{"id":"15","vertex_ids":["11","12"],"face_ids":["17"]},{"id":"16","vertex_ids":["12","9"],"face_ids":["17"]},{"id":"30","vertex_ids":["26","27"],"face_ids":["33","55"]},{"id":"31","vertex_ids":["27","28"],"face_ids":["17","33"]},{"id":"32","vertex_ids":["28","11"],"face_ids":["17"]},{"id":"22","vertex_ids":["10","26"],"face_ids":["33"]},{"id":"25","vertex_ids":["28","10"],"face_ids":["33"]},{"id":"53","vertex_ids":["50","51"],"face_ids":["55"]},{"id":"47","vertex_ids":["27","51"],"face_ids":["17","55"]},{"id":"49","vertex_ids":["50","26"],"face_ids":["55"]},{"id":"69","vertex_ids":["65","66"],"face_ids":["17","72"]},{"id":"70","vertex_ids":["66","51"],"face_ids":["17"]},{"id":"60","vertex_ids":["50","64"],"face_ids":["72"]},{"id":"63","vertex_ids":["66","50"],"face_ids":["72"]},{"id":"84","vertex_ids":["9","81"],"face_ids":["17"]},{"id":"85","vertex_ids":["81","82"],"face_ids":["17","89"]},{"id":"86","vertex_ids":["82","83"],"face_ids":["17","89"]},{"id":"87","vertex_ids":["83","65"],"face_ids":["17","72"]},{"id":"77","vertex_ids":["64","81"],"face_ids":["89"]},{"id":"80","vertex_ids":["83","64"],"face_ids":["89"]},{"id":"90","vertex_ids":["64","76"],"face_ids":["72"]},{"id":"91","vertex_ids":["76","83"],"face_ids":["72"]}],"faces":[{"id":"17","edge_ids":["84","85","86","87","69","70","47","31","32","15","16"],"edge_order":[1,1,1,1,1,1,0,1,1,1,1]},{"id":"33","edge_ids":["22","30","31","25"],"edge_order":[1,1,1,1]},{"id":"55","edge_ids":["47","53","49","30"],"edge_order":[1,0,1,1]},{"id":"72","edge_ids":["60","90","91","87","69","63"],"edge_order":[1,1,1,1,1,1]},{"id":"89","edge_ids":["77","85","86","80"],"edge_order":[1,1,1,1]}]},"images":[],"spaces":[{"id":"7","handle":null,"name":"Space 1 - 1","face_id":"17","building_unit_id":null,"thermal_zone_id":null,"space_type_id":null,"construction_set_id":null,"pitched_roof_id":null,"daylighting_controls":[],"below_floor_plenum_height":null,"floor_to_ceiling_height":null,"above_ceiling_plenum_height":null,"floor_offset":null,"open_to_below":null,"color":"#332288","type":"space"},{"id":"18","handle":null,"name":"Women 54","face_id":"33","building_unit_id":null,"thermal_zone_id":null,"space_type_id":null,"construction_set_id":null,"pitched_roof_id":null,"daylighting_controls":[],"below_floor_plenum_height":null,"floor_to_ceiling_height":null,"above_ceiling_plenum_height":null,"floor_offset":null,"open_to_below":null,"color":"#117733","type":"space"},{"id":"44","handle":null,"name":"Mens 52","face_id":"55","building_unit_id":null,"thermal_zone_id":null,"space_type_id":null,"construction_set_id":null,"pitched_roof_id":null,"daylighting_controls":[],"below_floor_plenum_height":null,"floor_to_ceiling_height":null,"above_ceiling_plenum_height":null,"floor_offset":null,"open_to_below":null,"color":"#999933","type":"space"},{"id":"56","handle":null,"name":"Lobby 50","face_id":"72","building_unit_id":null,"thermal_zone_id":null,"space_type_id":null,"construction_set_id":null,"pitched_roof_id":null,"daylighting_controls":[],"below_floor_plenum_height":null,"floor_to_ceiling_height":null,"above_ceiling_plenum_height":null,"floor_offset":null,"open_to_below":null,"color":"#ddcc77","type":"space"},{"id":"73","handle":null,"name":"Space 1 - 2","face_id":"89","building_unit_id":null,"thermal_zone_id":null,"space_type_id":null,"construction_set_id":null,"pitched_roof_id":null,"daylighting_controls":[],"below_floor_plenum_height":null,"floor_to_ceiling_height":null,"above_ceiling_plenum_height":null,"floor_offset":null,"open_to_below":null,"color":"#cc6677","type":"space"}],"shading":[{"id":"8","handle":null,"name":"Shading 1 - 1","face_id":null,"color":"#E8E3E5"}],"windows":[],"doors":[]}],"building_units":[],"thermal_zones":[],"space_types":[],"construction_sets":[],"window_definitions":[],"daylighting_control_definitions":[],"pitched_roofs":[],"version":"0.7.0"}
