Hello All,
I am currently researching about adaptive shading. My shading is quite complex geometry, so I model my shading as external shade and I use a grasshopper script, which is working, to create transmittance schedule to model the movement of the shading.
Previously I am using Polygon Clipping for the shadow calculation. The result and err file showed that there is too much polygon overlapped. After many times increasing the limit of polygon overlap, I tried to use the Pixel counting instead.
To test this method, I tried a simpler shading which enclosed all the window.
I simulated 3 case with different transmittance schedule: 1. Transparent --> Transmittance value of 1 throughout the year 2. Opaque --> Transmittance value of 0 throughout the year 3. Adaptive --> Transmittance value of 0 or 1 based on certain parameter.
I analyzed the window solar gain. It showed that there is no solar gain at all throughout the year.
I already use DetailedSkyDiffuse model and Timestep shading calculation. I am using E+ 9.3, but I already tried to run it in version 9.6 but the result was still the same. And if I run using Polygonclipping, the result did not show the same totally opaque problem. Is it an error in Energyplus or is there anything that I miss? Or it is already solved in the newest version.?
Thank you
