I'm trying to run ResStock (under the AWS method), and I'm having trouble with installing the library. I used the code shown here, and it ran successfully without any errors.
But afterwards, when I run "buildstock_docker --help" it shows that it is not recognized.
Note that I'm having the same issue as willyJohan here: https://unmethours.com/question/49991/setting-up-resstock-runs-on-local-windows-computer/
Any help would be greatly appreciated!
