This comes up when I run the simulationn and I don't understand why.
[14:00:02.000037 WARN] EnergyPlus reported area is 0 (m^2). OpenStudio reported area is 19289 (m^2).
[14:00:04.771128 WARN] Interior Lighting Summary section failed and was skipped because: Optional not initialized. Detail on error follows: /private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3344:in get'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3344:inblock in interior_lighting_section'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3343:in each'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3343:ininterior_lighting_section'
(eval):1:in block in run'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/measure.rb:291:ineval'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/measure.rb:291:in block in run'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/measure.rb:288:ineach'
/private/var/folders/4s/_jcc1y3969j6nzhw2bz64c_w0000gn/T/osmodel-1649440784-6/resources/measures/OpenStudioResults/measure.rb:288:in run'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:521:inapply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:117:inperform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'
:/openstudio_cli.rb:1067:in execute'
:/openstudio_cli.rb:803:inexecute'
:/openstudio_cli.rb:1855:in <main>'
eval:186:ineval'
eval:186:in require_embedded_absolute'
eval:171:inblock in require_embedded'
eval:165:in each'
eval:165:inrequire_embedded'
eval:124:in require'
eval:3:in<main>'
[14:00:05.331287 ERROR] Found error in state 'reporting_measures' with message ["920: NaN not allowed in JSON::/ruby/2.7.0/json/common.rb:286:in generate'\n:/ruby/2.7.0/json/common.rb:286:inpretty_generate'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/adapters/output/local.rb:111:in block in communicate_measure_attributes'\neval:443:inopen'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/adapters/output/local.rb:110:in communicate_measure_attributes'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:122:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1067:in execute'\n:/openstudio_cli.rb:803:inexecute'\n:/openstudio_cli.rb:1855:in <main>'\neval:186:ineval'\neval:186:in require_embedded_absolute'\neval:171:inblock in require_embedded'\neval:165:in each'\neval:165:inrequire_embedded'\neval:124:in require'\neval:3:in<main>'"]}
