After I install openstudio 3.2.0 in Macbook pro 2017, the HB daylight factor shows the error "1. Solution exception:Input "sensor-count" was not found for recipe "daylight_factor".". Besides, the "ModeltoOSM" shows "1. * Severe * <root>[ZoneHVAC:IdealLoadsAirSystem][Office_d4917ade Ideal Loads Air System] - Missing required property 'zone_supply_air_node_name'." "1. Solution exception: * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination." I am not sure what happened. I have installed the openstudio file in the ladybug_tool file.
