jEPlus: formula calculation error
Hi,
I am using jEPlus for optimization, and I used a formula to define the optimization objection.
I found the obtained results quite strange and I went back to check if I made a mistake in defining the formula,
and here I found out that the formula didn't work out for exponential functions, I used the tested formula: v5=2^3 and the evaluation results calculated by jEPlus is 1 instead of 8, see the attached screenshot.
I was wondering if this is a bug for the calculation of exponential functions or if I defined it in a wrong way.
Thanks in advance. image description
Hi,
and here I found out that the formula didn't work out for exponential a to the power of b functions, I used the tested formula: v5=2^3 and the evaluation results calculated by jEPlus is 1 instead of 8, see the attached screenshot.
I was wondering if this is a bug for the calculation of exponential this type of functions or if I defined it in a wrong way.
