I have got these errors after run an air cooled chiller simulation. Please help me figure them out. How can I fix these errors. Thank you.
Program Version,EnergyPlus, Version 9.6.0-4b123cf80f, YMD=2022.04.07 00:27, * Severe * Line: 24044 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 24044 Index: 0 - Error parsing "AirLoopHVAC:ControllerList". Error in following line. * Severe * ~~~ Controller:WaterCoil, !- Controller Object Type 9 * Severe * Line: 24054 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 24054 Index: 0 - Error parsing "Controller:WaterCoil". Error in following line. * Severe * ~~~ Controller:WaterCoil, !- Controller Object Type 14 * Severe * Duplicate name found for object of type "Controller:WaterCoil" named "Controller Water Coil 21". Overwriting existing object. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=7 ..... Last severe error=Duplicate name found for object of type "Controller:WaterCoil" named "Controller Water Coil 21". Overwriting existing object. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 7 Severe Errors; Elapsed Time=00hr 00min 0.15sec
