Hi,
I am using jEPlus for the optimization of PV panels. I have defined 100 parameters, and I have used RVIs to generate the hourly DemandGeneration.csv file inside of each job folder for post-processing defined using scripts.
However, it seems that the simulation crashed due to a large number of parameters--->long job folder name--->exceed character limitation defined by windows which is around 260---->cannot generate job folder--->error:directory name is invalid
I was wondering if there is a way to fix this error.
Thanks in advance.
