I'm having an issue with EnergyPlus 9.6. I added a DOAS to my model, but my model fails to complete the sizing of the cooling coil of the DOAS unit. The sequence of my setup for the DOAS is (OA - heating coil - cooling coil - fan).
For some reason the [Coil inlet air temperature used for sizing = -997.59 [C]], and I tried everything I can to fix it.
I tried to change (Design Inlet/Outlet Air Temperature) from (autosize) to fixed temperatures, but for some reason I still see the same error.
Here is the full list of errors I'm seeing:
** Warning ** SizeWaterCoil: Potential issue with equipment sizing for Coil:Cooling:Water B1 DOAS CC
** ~~~ ** ...Rated Total Cooling Capacity = -112120230.17 [W]
** ~~~ ** ...Air flow rate used for sizing = 90.45075 [m3/s]
** ~~~ ** ...Outdoor air fraction used for sizing = 0.00
** ~~~ ** ...Coil inlet air temperature used for sizing = -997.59 [C]
** ~~~ ** ...Coil outlet air temperature used for sizing = 17.50 [C]
** Severe ** SizeWaterCoil Coil:Cooling:Water B1 DOAS CC, Developer Error: Component sizing incomplete.
** ~~~ ** SizingString = Design Inlet Air Humidity Ratio [kgWater/kgDryAir], SizingResult = -99998.9
** Severe ** Developer Error: sizing of Design Inlet Air Humidity Ratio [kgWater/kgDryAir] failed.
** ~~~ ** Occurs in Coil:Cooling:Water B1 DOAS CC
** Warning ** SizeWaterCoil: Coil="B1 DOAS CC", Cooling Coil has leaving humidity ratio > entering humidity ratio.
** ~~~ ** Wair,in = -999.000000 [kgWater/kgDryAir]
** ~~~ ** Wair,out = 1.200000E-002 [kgWater/kgDryAir]
** ~~~ ** ....coil leaving humidity ratio will be reset to:
** ~~~ ** Wair,out = -999.000000 [kgWater/kgDryAir]
** ~~~ ** SizingString = Design Outlet Air Humidity Ratio [kgWater/kgDryAir], SizingResult = -99998.9
** Severe ** Developer Error: sizing of Design Outlet Air Humidity Ratio [kgWater/kgDryAir] failed.
** ~~~ ** SizingString = Design Coil Load [W], SizingResult = -99998.9
** Severe ** Developer Error: sizing of Design Coil Load [W] failed.
** Fatal ** Preceding water coil sizing errors cause program termination
